The developer environment enables you to extend Sun Management Center software functionality in various ways. You can perform the following tasks:
Create custom management modules
Create client programs that interface with Sun Management Center
Integrate applications with the Sun Management Center console
If you are installing the developer environment, you should run the Sun Management Center 3.5 developer environment and the Sun Management Center 3.5 production environment on separate, dedicated servers.
For further information about the Sun Management Center 3.5 developer environment, see the Sun Management Center 3.5 Developer Environment Reference Manual.
