You should run the setup process in the following situations:
When you have completed installing Sun Management Center 3.5 for the first time but have not run setup
When you change your setup configuration, such as changing the server context
When instructed to do so in your add-on software or hardware supplement
When you need to reconfigure your entire Sun Management Center 3.5 installation
When you need to set up a new add-on product
When you need to re-create the Sun Management Center database
