Sun Management Center 3.5 Installation and Configuration Guide
es-uninst Options
The syntax for the es-uninst command is:
es-uninst [ -f | -F | -X | -h | -v ]
The following table describes the es-uninst command parameters.
Table B–1 es-uninst Options
Option
Description
-F
Uninstall the entire Sun Management Center installation without prompting for confirmation and without stopping any running Sun Management Center processes.
This option should be used only in a situation when the executables that are called while stopping Sun Management Center processes are not present where expected.
For example, if the operating environment has been upgraded after Sun Management Center was installed from the Solaris 7 release to the Solaris 8 release, then some dynamically generated path names will be incorrect. In this case, this option avoids errors being reported during the uninstall process.
-f
Uninstall the entire Sun Management Center installation without prompting for confirmation.
-h
List the es-uninst options.
-v
Perform the uninstall using verbose mode.
-X
Complete Sun Management Center uninstall without interaction. All processes are stopped, then the entire Sun Management Center installation, including the database and all add-ons, is removed. You are not given the opportunity to save your configuration data.
