The syntax for the es-inst command is:
es-inst [-S dir][-T dir][-R dir][-C file][-A file][avh]The following table describes the es-inst parameters.
Table B–2 es-inst Options
Option |
Description |
-A |
filename |
Perform an automated installation using the specified configuration file filename. This option is ignored if —C is also used. |
-C |
filename |
Specify a file in which to store the configuration details entered during installation and setup. The file can be used for subsequent automated installation. |
-R |
/path/remote-machine |
Install Sun Management Center on a remote machine that is network file system read/write accessible from the root login account on the local machine. |
-S |
directory |
Specify the source directory. |
-T |
directory |
Specify the target directory. |
-a |
Perform an agent-only product installation. See To Install or Update Agents From an Agent-Update Image Using agent-update.bin. |
-h |
List the es-inst options. |
-v |
Perform an installation using verbose full log mode. |
