Sun Management Center 3.5 Installation and Configuration Guide
Client-to-Server Security
Communication between the Sun Management Center server layer and clients such as consoles and command-line interfaces is performed using Java Technology Remote Method Invocation (RMI) in conjunction with a comprehensive product-specific security model. The security model allows clients to operate in either low, medium or high security modes, which affects the level of message authentication that is performed.
Because of the potential performance impact of the higher security levels, you should carefully consider your message authentication requirements.
