Sun Management Center 3.5 Installation and Configuration Guide
es-validate Options
The syntax for the es-validate command is as follows:
es-validate [-s server [-r serverport] [-u user-name [-p password ]]] [-a agenthost [-b agentport] [-d]] [-c] [-o outfile]
The following table describes the es-validate parameters.
Table 7–1 es-validate Options
Option
Modifying Options
Description
-a
agenthost
Check connectivity with agent host machine agenthost.
-b
agentport
The SNMP port number associated with agentport.
-c
Show all the agents in the context of the Sun Management Center server specified with -s option.
-d
Show the version number of the agent on agenthost.
-o
outfile
Store the output of es-validate in file outfile. outfile should be an absolute file path. The default is an arbitrary file name in /tmp.
-p
password
The password for -uuser-name If not specified, and -uuser-name is specified, you are prompted for the password.
-r
serverport
The Sun Management Center RMI port number. If not specified, port 2099 is used.
-s
server
The Sun Management Center server host name. If not specified, the current host is used.
-u
user-name
The user name used to connect with the Sun Management Center server. The -u user name parameter is mandatory for login checks.
