The Sun Management Center server uses SNMP to communicate with the Sun Management Center agents. SNMP also communicates with the other server components, such as the Topology manager, Configuration manager, Event manager, and Trap handler. By contrast, the Sun Management Center server uses remote method invocation (RMI) to communicate with the Sun Management Center consoles.
The SNMP port definitions for Sun Management Center components are defined in two files:
The /var/opt/SUNWsymon/cfg/domain-config.x file exists in every machine running any Sun Management Center component
The /var/opt/SUNWsymon/cfg/server-config.x file exists on machines that have the Sun Management Center server component installed
The domain-config.x file contains one configuration block for each of the SNMP-based Sun Management Center agents. Each configuration block contains at least one line that defines the port address for the corresponding agent. The default port definition for the Sun Management Center server is in the server-config.x file.
You can manually add hosts with Sun Management Center agents that use port addresses other than 161 to the administrative domain through the Create Topology Object window. Alternatively, you can discover these hosts automatically by specifying the port number in the discovery parameters. For more information on the Create Topology Object window, see “Manually Adding Objects to the Management Information Base” in the Sun Management Center 3.5 User's Guide. For more information on how hosts are discovered automatically, see “Adding Objects to the MIB Using the Discovery Manager” in the Sun Management Center 3.5 User's Guide. Because you can only specify one port number in addition to port 161, you should select an alternate port number and use that number for all agent installations.
