Sun Management Center 3.5 Installation and Configuration Guide
Using es-backup
You should use es-backup to back up your database and configuration data as follows.
The syntax of the es-backup command is as follows:
es-backup [ -d backup-directory] [-y]
The following table describes the es-backup command parameters.
Table 9–1 es-backup Options
Option
Modifying Options
Description
-d
backup-directory
Back up the database and configuration data to the directory backup-directory.
-h
List the options for es-backup.
-y
Perform a non-interactive backup. You will not be prompted to stop Sun Management Center processes, nor will you be prompted for a backup directory name.
Note –
If you do not specify a backup directory using the --d option, all database and configuration data is backed up to the directory /var/opt/SUNWsymon/backup.
To both minimize and prevent data loss, you should run es-backup on a routine basis to enable recovery of your most current data in the event of a system failure. You can create a cron entry for thees-backup -y script to run the script on a periodic basis. As part of the cron entry, you may also want to copy the contents of /var/opt/SUNWsymon/backup to an alternate directory.
Note –
By default, a non-interactive backup overwrites the contents of /var/opt/SUNWsymon/backup. If you have previously performed a non-interactive backup of Sun Management Center data, and you want to save the previous backup, copy the contents of the directory /var/opt/SUNWsymon/backup to another location before running a non-interactive backup.
The following procedure assumes that you installed Sun Management Center in the default directory /opt. If you did not install Sun Management Center in /opt, replace /opt with the name of the directory you specified in Step 8 in To Install Sun Management Center 3.5 on the Solaris Platform.
To Manually Back Up Sun Management Center Data to the Default Directory
  1. Log in as root on the Sun Management Center server machine.
  2. Stop all Sun Management Center processes.
    Type the command /opt/SUNWsymon/es-stop -A and press Return.
  3. Backup your Sun Management Center data.
    Type the command /opt/SUNWsymon/es-backup and press Return.
    If any Sun Management Center processes are still running, you are notified that Sun Management Center must be shut down.
    You are asked whether you want to proceed. Type y and press Return.
  4. Specify the backup directory.
    You are prompted for the directory path in which to store the backup. The default location /var/opt/SUNWsymon/backup is displayed.
    • To accept the default backup directory /var/opt/SUNWsymon/backup, press Return.
      If a prior backup has been performed using the default directory /var/opt/SUNWsymon/backup, you are asked whether to delete the old backups.
      • To keep the old backups, type n to exit the backup process, then copy /var/opt/SUNWsymon/backup to a different directory.
      • To overwrite the old backups, type y.
      es-backup stops all running processes, and then backs up the database and configuration data to /var/opt/SUNWsymon/backup. When the backup is completed, es-backup starts all Sun Management Center processes.
    • To specify a different backup directory, type the name of the directory and press Return.
      For example:
      # Enter full directory path to store the backup data files
         [/var/opt/SUNWsymon/backup]: /backup-set-1
      If the directory does not exist, you are asked whether you want to create the directory. Type y and press Return.
      es-backup stops all running processes, and then backs up the database and configuration data to the directory you specified. When the backup is completed, es-backup starts all Sun Management Center processes.
  5. Validate the backup.
    Type the command /opt/SUNWsymon/sbin/es-restore -c and press Return.
    You are prompted to enter the full directory path to the backup files. The default backup directory path /var/opt/SUNWsymon/backup is displayed.
    • If you chose the default backup directory /var/opt/SUNWsymon/backup, press Return.
    • If you specified a different backup directory, type the full path and name of the directory and press Return.
    es-restore validates the data in the backup directory. You are informed whether the backup data is valid.
    • If the backup is not valid, examine the backup log file /var/opt/SUNWsymon/install/backup_host-name.date and time string.process-id where:
      • host-name is the name of the server you used to create the backup
      • date and time string is the year, date, and time the backup was created
      • process-id is the process ID of the es-backup session that created the backup.
    • If the backup is valid, copy the backup directory to a different directory for safe keeping.
    The es-backup log file is /var/opt/SUNWsymon/install/backup_host-name.date and time string.process-id where:
    • host-name is the name of the server you used to perform the backup.
    • date and time string is the year, date, and time the backup was run.
