Sun Management Center 3.5 Installation and Configuration Guide
Generating Performance Reporting Manager Reports
A wide range of reports can be generated by specifying different numbers of agents, numbers of data properties, and report durations such as 4 hours to 1 month.
Typical reports take a few seconds to several minutes to generate. The actual time required is affected by the following factors:
For example, on a medium Sun Management Center server configured with the performance reporting manager add-on, a relatively simple report that includes 5 properties for 1 agent over the last 24 hours can be generated in about 20 seconds. Conversely, a more substantial report that includes 5 properties for 5 agents over the last 7 days can take around 10 minutes to generate.
Note –
A medium Sun Management Center server with the performance reporting manager add-on is assumed to be an Ultra-80 with two 450MHz UltraSPARC II CPUs, 1 GB RAM, and 1 GB swap. It is also assumed that the Ultra-80 is monitoring 300 agents and collecting 300 data properties per agent for the performance reporting manager.
