Sun Management Center 3.5 Installation and Configuration Guide
Startup of Multiple Platform Agents
Sun Fire platform agents refresh their management information hourly by default. When multiple platform agents are deployed on the same host and are initialized at the same time, the agents tend to perform their data refreshes in quick succession. If too many platform agents attempt to refresh their data concurrently, the overall responsiveness of the host system can be adversely affected.
To reduce the likelihood of concurrent operations by multiple platform agents on the same host, do not start all of the platform agents at the same time.
Deploying Sun Fire Platform Agents on a Dedicated Host
The following table lists typical hardware configurations and the corresponding number of platform agents that can be deployed on the dedicated host system.
Table C–7 Dedicated Host: Sun Fire Platform Agent Capacity
Representative Hardware Configurations
Maximum Number of Platform Agents
Netra X1, Netra T1 or Sun Blade 100 with a single 500 MHz UltraSPARC IIe CPU, 1 Gbyte of RAM and 1 Gbyte of swap
5 to 7
Sun Enterprise 420R or Ultra 60 with dual 450 MHz UltraSPARC II CPUs, 1 Gbyte of RAM, and 1 Gbyte of swap
11 to 15
Sun Fire 280R, Netra T4, or Sun Blade 1000 with dual 750 MHz UltraSPARC III CPUs, 1 Gbyte of RAM, and 1 Gbyte of swap
14 to 20
Because platform agent resource use can vary, the limits shown in the table represent a range of acceptable values that leave sufficient capacity to ensure that operational peaks do not exhaust system capacity. Larger Sun Fire platforms require greater platform agent resources, with the result that fewer platform agents can be run on a single host. Conversely, smaller Sun Fire platforms require fewer platform agent resources, so more platform agents can be run on a single host.
Deploying Sun Fire Platform Agents on a Server Layer Host
The hardware sizing requirements of a host system running the Sun Management Center server layer are a function of the number of platform agents managed by the server layer and the management activity in the system.
Only large multiple-CPU systems should be considered for running both the Sun Management Center server layer and Sun Fire platform agents. The deployment of platform agents on a server layer host with limited capacity can adversely affect the overall performance of Sun Management Center.
Assuming a moderate level of management activity of fewer than 1000 events per host per day, the maximum number of platform agents than can be deployed on a Sun Management Center server layer host is the function of the number of agents under management and the machine class. The following table lists typical system capacity.
Table C–8 Server Layer Host: Sun Fire Platform Agent Capacity
Number of Agents Under Management
Sun Enterprise 420R
Sun Fire 280R
100
6
7
300
5
7
500
4
6
750
NA
6
Sun Enterprise 420R denotes an Enterprise 420R or Ultra 60 system with a dual 450 MHz UltraSPARC-II server layer host, with 1 Gbyte of RAM and 1 Gbyte of swap.
Sun Fire 280R denotes a Sun Fire 280R, a Sun Blade 1000, or a Netra T4 system with a dual 750 MHz UltraSPARC III server host with 1 Gbyte of RAM and 1 Gbyte of swap.
For Sun Fire Sun Management Center installation procedures, see Sun Management Center 3.5 Software Supplement for Sun Fire 6800/4810/4800/3800 Systems.
