Sun Management Center 3.5 Installation and Configuration Guide
Creating Installation CD Images
To create the Sun Management Center CD images, you create a directory to contain the images, copy each CD to the directory, and then share the directory using network file system mounting.
To Create CD Images
  1. In a terminal window, log in as root by typing su - root.
  2. Create a directory to which you will copy each CD.
    For example:
    # mkdir /SunManagementCenter
  3. Go to the directory you created for the CD images.
    For example:
    # cd /SunManagementCenter
  4. Create a diskn directory for each CD, where n is the sequence number of the disk.
    For example:
    /SunManagementCenter# mkdir disk1 disk2
  5. Make sure the vold daemon is running.
    /SunManagementCenter# ps -eaf | grep vold
    root 19033 19000  0 08:37:55 pts/9    0:00 vold
    If the grep command returns only the system prompt, then the vold daemon is not running, and must be started as follows:
    /SunManagementCenter# /usr/sbin/vold &
  6. Insert Sun Management Center 3.5 CD 1 of 2 in your CD-ROM drive.
  7. List the contents of the Sun Management Center 3.5 installation CD 1. Then copy the contents to the disk1 subdirectory.
    When the copy completes, list the contents of the CD and the directory to verify the contents of the disk image.
    For example:
    /SunManagementCenter# ls -p /cdrom
    cdrom0            sunmc_3_5_sparc/
    /SunManagementCenter# cp -r /cdrom/sunmc_3_5_sparc/.* disk1
    /sunmanagementcenter > ls -acp /cdrom/cdrom0sunmc_3_5_sparc
    .          .CD        Copyright  image/      lib/
    ..         .CD01      classes/    install/    sbin/
    /sunmanagementcenter > ls -acp disk1
    Caution – Caution –
    cdrom0 is a symbolic link. Copy only the Sun Management Center directory as shown in the above example.
  8. Eject CD.1 of 2.
    SunManagementCenter# eject
  9. Insert Sun Management Center 3.5 CD 2 of 2 in your CD-ROM drive.
  10. List the contents of the Sun Management Center 3.5 installation CD 2. Then copy the contents to the disk2 subdirectory.
    For example:
    cdrom0              sunmc_3_5_sparc_2/
    /SunManagementCenter# cp -r /cdrom/sunmc_3_5_sparc_2/.* disk2
    /sunmanagementcenter > ls -acp /cdrom/cdrom0sunmc_3_5_sparc_2
    .          ..         .CD        .CD01      .CD02      Copyright  image/
    /sunmanagementcenter > ls -acp disk2
  11. Eject CD 2 of 2.
  12. Make the Sun Management Center 3.5 CD image directory NFS-shared.
    Using NFS to share the CD image directory enables you to install Sun Management Center 3.5 from other machines by using the CD installation images instead of manually installing from the CDs.
    1. Stop the Network File System daemon mountd:
      /SunManagementCenter# /etc/init.d/nfs.server stop
    2. Add the following line to the /etc/dfs/dfstab file.
      share -F nfs -o ro cd-image-dir
      where cd-image-dir is the Sun Management Center 3.5 cd-image directory that you created in Java Environment Variables and Path.
      For example: share -F nfs -o ro /SunManagementCenter
    3. Save and close /etc/dfs/dfstab.
    4. Start the Network File System daemon mountd:
      /SunManagementCenter# /etc/init.d/nfs.server start
      The Sun Management Center 3.5 cd-image directory is now accessible from other machines.
    You can now use the Sun Management Center CD images to install Sun Management Center 3.5, or to upgrade previous versions of Sun Management Center as described in the following chapters.
