System configuration data is logged on the agent machines by the Performance Reporting Manager logging component. This logging component is added to the agent machine during installation. The data is then transferred to the Sun Management Center 3.5 server machine and loaded into the database. Report data is obtained by making queries to the database located on the Sun Management Center 3.5 server machine. This method is similar to the way the data for standard performance reports is obtained.
The report options are predefined in the report request. The report output format for all standard system configuration reports is a table. The following nine standard system configuration reports are included with Performance Reporting Manager. They are organized by their category and subcategory names.
Alarm
Alarms
Alarm Details – This report lists all open alarms for each host. The report data includes host name, operating system, alarm severity, alarm status, open date, and alarm message. You provide the host name and port when the report is run.
Alarm Summary – This report lists the alarm status and alarm count for each host. The report data includes the host name and alarm status. The report provides detail for all hosts in the server context.
Alarm Severity Count By Host – This report lists the alarm severity count for each host. The report data includes the host name, alarm severity, and alarm status. The report provides detail for all hosts in the server context.
Hardware
System
System Details – This report lists the system details by host name. All hosts in the server context that have both the Config-Reader add-on and Performance Reporting Manager installed are included. The report data includes the host name, operating system, system clock frequency, platform type, total disks, total memory, total processors, and total tape devices.
Platform Summary – This report lists the platform type by host name. All hosts in the server context that have the Config-Reader add-on and Performance Reporting Manager installed are included. The report data includes platform.
OS Summary – This report lists the operating system by host name. All hosts in the server context that have the Config-Reader add-on and Performance Reporting Manager installed are included. The report data includes the operating system.
Configuration
Software
Packages
Hosts with SUNWcsr package – This report lists the hosts that have the SUNWcsr package installed. The report data includes the host name, package instance, package name, category, version, package description, and install date. The report provides detail for all hosts in the server context.
Package Details – This report lists all the software packages installed on a specified host. The report data includes the host name, package instance, package name, category, version, package description, and install date. The host name and port is entered when the report is run.
Patches
You can resize the columns in any tabular report by dragging the sides of the column header. Additionally, you can sort any tabular report by double-clicking the column headers. The report then sorts according to the header selected.
