Changes That Will Be Made to System Files
The following system files are modified when you install Solaris Resource
Manager.
Table 1-2 Added System Files
/dev/srmdrv [Created during reboot following installation.]
/etc/init.d/init.srm
/etc/rc0.d/K52srm
/etc/rc1.d/K52srm
/etc/rc2.d/S10srm
/etc/srm/limconf
/etc/srm/nolnode
/etc/system.noshrload
/kernel/drv/srmdrv [ This file is only used in the Solaris Resource Manager
1.0 and 1.1 releases.]
/kernel/drv/srmdrv.conf
/kernel/misc/srmlim
/kernel/sched/SHR
/kernel/sys/srmlimitsys
/usr/lib/srm/liblim.so
/usr/lib/srm/liblim.so.1
/usr/lib/srm/srmscru
/usr/srm/lib/limdaemon
/usr/srm/bin/liminfo
/usr/srm/bin/limreport
/usr/srm/bin/srmkill
/usr/srm/bin/srmstat
/usr/srm/bin/srmuser
/usr/srm/sbin/limadm
/usr/srm/sbin/srmadm
/usr/lib/class/SHR/SHRdispadmin
/usr/lib/class/SHR/SHRpriocntl
/usr/lib/security/pam_srm.so
/usr/lib/security/pam_srm.so.1
Table 1-3 Added System Files, Solaris Resource Manager 1.3 Only
/etc/init.d/rcapd
/etc/rc0.d/K10rcapd
/etc/rc1.d/K10rcapd
/etc/rc2.d/S99rcapd
/usr/srm/bin/rcapstat
/usr/srm/sbin/rcapadm
/usr/srm/sbin/rcapd
/usr/srm/sbin/sparcv7/rcapd
/usr/srm/sbin/sparcv9/rcapd
Table 1-4 Updated System Files
/etc/devlink.tab
/etc/pam.conf
/etc/passwd
/etc/shadow
/etc/system
The following table contains useful but unsupported scripts.
Table 1-5 Unsupported System Files
/usr/srm/unsupport/limid
/usr/srm/unsupport/passwd_lnodes
/usr/srm/unsupport/schedtree
