On Sun Cluster, Solaris Resource Manager can be configured so that the resource allocation configuration described in the lnode configuration (/var/srm/srmDB) remains the same in normal cluster operation and in switchover or failover situations. For more information, see Sample Share Allocation.
The following sections are example scenarios.
The first two sections, Two-Node Cluster With Two Applications and Two-Node Cluster With Three Applications, show failover scenarios for entire nodes.
The section Failover of Resource Group Only illustrates failover operation for an application only.
In a cluster environment, an application is configured as part of a resource group (RG). When a failure occurs, the resource group, along with its associated applications, fails over to another node. In the following examples, Application 1 (App-1) is configured in resource group RG-1, Application 2 (App-2) is configured in resource group RG-2, and Application 3 (App-3) is configured in resource group RG-3.
Although the numbers of assigned shares remain the same, the percentage of CPU resources allocated to each application will change after failover, depending on the number of applications running on the node and the number of shares assigned to each active application.
In these scenarios, assume the following configurations.
All applications are configured under a common parent lnode.
The applications are the only active processes on the nodes.
The limits databases are configured the same on each node of the cluster.
You can configure two applications on a two-node cluster such that each physical host (phys-schost-1, phys-schost-2) acts as the default master for one application. Each physical host acts as the backup node for the other physical host. All applications must be represented in the Solaris Resource Manager limits database files on both nodes. When the cluster is running normally, each application is running on its default master, where it is allocated all CPU resources by Solaris Resource Manager.
After a failover or switchover occurs, both applications run on a single node where they are allocated shares as specified in the configuration file. For example, this configuration file specifies that Application 1 is allocated 80 shares and Application 2 is allocated 20 shares.
# limadm set cpu.shares=80 App-1 # limadm set cpu.shares=20 App-2 ... |
The following diagram illustrates the normal and failover operations of this configuration. Note that although the number of shares assigned does not change, the percentage of CPU resources available to each application can change, depending on the number of shares assigned to each process demanding CPU time.
On a two-node cluster with three applications, you can configure it such that one physical host (phys-schost-1) is the default master of one application and the second physical host (phys-schost-2) is the default master for the remaining two applications. Assume the following example limits database file on every node. The limits database file does not change when a failover or switchover occurs.
# limadm set cpu.shares=50 App-1 # limadm set cpu.shares=30 App-2 # limadm set cpu.shares=20 App-3 ... |
When the cluster is running normally, Application 1 is allocated 50 shares on its default master, phys-schost-1. This is equivalent to 100 percent of CPU resources because it is the only application demanding CPU resources on that node. Applications 2 and 3 are allocated 30 and 20 shares, respectively, on their default master, phys-schost-2. Application 2 would receive 60 percent and Application 3 would receive 40 percent of CPU resources during normal operation.
If a failover or switchover occurs and Application 1 is switched over to phys-schost-2, the shares for all three applications remain the same, but the percentages of CPU resources are re-allocated according to the limits database file.
Application 1, with 50 shares, receives 50 percent of CPU.
Application 2, with 30 shares, receives 30 percent of CPU.
Application 3, with 20 shares, receives 20 percent of CPU.
In a configuration in which multiple resource groups have the same default master, it is possible for a resource group (and its associated applications) to fail over or be switched over to a backup node, while the default master remains up and running in the cluster.
During failover, the application that fails over will be allocated resources as specified in the configuration file on the backup node. In this example, the limits database files on the primary and backup nodes have the same configurations.
For example, this sample configuration file specifies that Application 1 is allocated 30 shares, Application 2 is allocated 60 shares, and Application 3 is allocated 60 shares.
# limadm set cpu.shares=30 App-1 # limadm set cpu.shares=60 App-2 # limadm set cpu.shares=60 App-3 ... |
The following diagram illustrates the normal and failover operations of this configuration, where RG-2, containing Application 2, fails over to phys-schost-2. Note that although the number of shares assigned does not change, the percentage of CPU resources available to each application can change, depending on the number of shares assigned to each application demanding CPU time.
