Task |
Description |
For Instructions |
Activate the extended accounting facility. |
Use extended accounting to monitor resource consumption by each project running on your system. You can use the extended accounting subsystem to capture historical data for tasks, processes, and flows. |
How to Activate Extended Accounting for Processes, Tasks, and Flows, How to Activate Extended Accounting With a Startup Script |
Display extended accounting status. |
Determine the status of the extended accounting facility. | |
View available accounting resources. |
View the accounting resources available on your system. | |
Deactivate the process, task, and flow accounting facility. |
Turn off the extended accounting functionality. | |
Use the Perl interface to the extended accounting facility. |
Use the Perl interface to develop customized reporting and extraction scripts. |
