 How to Define a Project and View the Current
Project
ProjectThis example shows how to use the projadd command to add a project entry and the projmod command to alter that entry.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Using the Solaris Management Tools With RBAC (Task Map) in System Administration Guide: Basic Administration.
View the default /etc/project file on your system by using projects -l.
| # projects -l
system:0::::
user.root:1::::
noproject:2::::
default:3::::
group.staff:10::::system
        projid : 0
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
user.root
        projid : 1
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
noproject
        projid : 2
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
default
        projid : 3
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
group.staff
        projid : 10
        comment: ""
        users  : (none)
        groups : (none)
        attribs:  |
Add a project with the name booksite. Assign the project to a user who is named mark with project ID number 4113.
| # projadd -U mark -p 4113 booksite |
View the /etc/project file again.
| # projects -l
system
        projid : 0
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
user.root
        projid : 1
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
noproject
        projid : 2
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
default
        projid : 3
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
group.staff
        projid : 10
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
booksite
        projid : 4113
        comment: ""
        users  : mark
        groups : (none)
        attribs:  |
Add a comment that describes the project in the comment field.
| # projmod -c `Book Auction Project' booksite |
View the changes in the /etc/project file.
| # projects -l
system
        projid : 0
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
user.root
        projid : 1
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
noproject
        projid : 2
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
default
        projid : 3
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
group.staff
        projid : 10
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
booksite
        projid : 4113
        comment: "Book Auction Project"
        users  : mark
        groups : (none)
        attribs:  |
To bind projects, tasks, and processes to a pool, see Setting Pool Attributes and Binding to a Pool.
 How to Delete a Project From the /etc/project File
How to Delete a Project From the /etc/project FileThis example shows how to use the projdel command to delete a project.
Remove the project booksite by using the projdel command.
| # projdel booksite |
Display the /etc/project file.
| # projects -l
system
        projid : 0
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
user.root
        projid : 1
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
noproject
        projid : 2
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
default
        projid : 3
        comment: ""
        users  : (none)
        groups : (none)
        attribs:
group.staff
        projid : 10
        comment: ""
        users  : (none)
        groups : (none)
        attribs:  |
Log in as user mark and type projects to view the projects that are assigned to this user.
| # su - mark # projects default |
If no editing options are given, the projmod command validates the contents of the project file.
To validate a NIS map, as superuser, type the following:
| # ypcat project | projmod -f — |
The ypcat project | projmod -f — command is not yet implemented.
To check the syntax of the /etc/project file, type the following:
| # projmod -n |
Use the id command with the -p flag to display the current project membership of the invoking process.
| $ id -p uid=100(mark) gid=1(other) projid=3(default) |
 How to Create a New Task
How to Create a New TaskLog in as a member of the destination project, booksite.
Create a new task in the booksite project by using the newtask command with the -v (verbose) option to obtain the system task ID.
| machine% newtask -v -p booksite 16 |
The execution of newtask creates a new task in the specified project, and places the user's default shell in this task.
View the current project membership of the invoking process.
| machine% id -p uid=100(mark) gid=1(other) projid=4113(booksite) |
The process is now a member of the new project.
 How to Move a Running Process Into a New Task
How to Move a Running Process Into a New TaskThis example shows how to associate a running process with a different task and new project. To perform this action, you must either be superuser, or be the owner of the process and be a member of the new project.
If you are the owner of the process or a member of the new project, you can skip this step.
Obtain the process ID of the book_catalog process.
| # pgrep book_catalog 8100 |
Associate process 8100 with a new task ID in the booksite project.
| # newtask -v -p booksite -c 8100 17 |
The -c option specifies that newtask operate on the existing named process.
Confirm the task to process ID mapping.
| # pgrep -T 17 8100 |
