System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones
Mounting File Systems in Zones
When file systems are mounted from within a zone, the nodevices option applies. For example, if a zone is granted access to a block device (/dev/dsk/c0t0d0s7) and a raw device (/dev/rdsk/c0t0d0s7) corresponding to a UFS file system, the file system is automatically mounted nodevices when mounted from within a zone. This rule does not apply to mounts specified through a zonecfg configuration.
Options for mounting file systems in non-global zones are described in the following table. Procedures for these mounting alternatives are provided in Configuring, Verifying, and Committing a Zone and Mounting File Systems in Running Non-Global Zones.
Any file system type not listed in the table can be specified in the configuration if it has a mount binary in /usr/lib/fstype/mount.
File System
Mounting Options in a Non-Global Zone
AutoFS
Cannot be mounted using zonecfg, cannot be manually mounted from the global zone into a non-global zone. Can be mounted from within the zone.
CacheFS
Cannot be used in a non-global zone.
FDFS
Can be mounted using zonecfg, can be manually mounted from the global zone into a non-global zone, can be mounted from within the zone.
HSFS
LOFS
MNTFS
NFS
Cannot be mounted using zonecfg. V2, V3, and V4, which are the versions currently supported in zones, can be mounted from within the zone.
PCFS
PROCFS
TMPFS
UDFS
UFS
XMEMFS
Support for this file system is being removed from the Solaris system in a future release.
ZFS
Can be mounted using the zonecfg dataset and fs resource types.
For more information, see How to Configure the Zone, Mounting File Systems in Running Non-Global Zones, and the mount(1M) man page.
