Task |
Description |
For Instructions |
Configure a non-global zone. |
Use the zonecfg command to create a zone, verify the configuration, and commit the configuration. You can also use a script to configure and boot multiple zones on your system. You can use the zonecfg command to display a non-global zone's configuration. |
Configuring, Verifying, and Committing a Zone, Script to Configure Multiple Zones |
Modify a zone configuration. |
Use this procedure to modify a resource type in a zone configuration or add a dedicated device to a zone. | |
Revert a zone configuration or delete a zone configuration. |
Use the zonecfg command to undo a resource setting made to a zone configuration or to delete a zone configuration. |
Using the zonecfg Command to Revert or Remove a Zone Configuration |
Delete a zone configuration. |
Use the zonecfg command with the delete subcommand to delete a zone configuration from the system. |
