System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones
Using pkgadd in the Global Zone
The pkgadd utility can be used with the -G option in the global zone to add the package to the global zone only. The package is not propagated to any other zones. Note that if SUNW_PKG_THISZONE=true, you do not have to use the -G option. If SUNW_PKG_THISZONE=false, the -G option will override it.
When you run the pkgadd utility in the global zone, the following actions apply.
Adding a Package to the Global Zone and to All Non-Global Zones
To add a package to the global zone and to all non-global zones, execute the pkgadd utility in the global zone. As the global administrator, run pkgadd without the -G option.
A package can be added to the global zone and to all non-global zones without regard to the area affected by the package.
The following steps are performed by the pkgadd utility:
Adding a Package to the Global Zone Only
To add a package to the global zone only, as the global administrator in the global zone, execute the pkgadd utility with the -G option only.
A package can be added to the global zone if the following conditions are true:
Adding a Package Installed in the Global Zone to all Non-Global Zones
To add a package that is already installed in the global zone to all non-global zones, you must currently remove the package from the global zone and reinstall it in all zones.
These are the steps used to add a package that is already installed in the global zone to all of the non-global zones:
  1. In the global zone, use pkgrm to remove the package.
  2. Add the package without using the -G option.
