Installing and Administering Solaris Container Manager 1.1
ProcedureTo Request a Resource Utilization Report For a Host
Use this procedure if you want to obtain a daily, weekly, or monthly report for a host.
Steps
  1. Set the browser's cache to refresh every time.
  2. In the Hosts view, select the host from the navigation window.
  3. Select the Utilization tab.
    The CPU usage and memory usage of the host for the last 24 hours are displayed.
    Note –
    (On Solaris 10) The CPU usage, memory usage, and bandwidth usage are displayed.
  4. Click the Graph Properties link.
  5. Choose whether to generate a report for the entire host or only for a resource object in the host.
    Note –
    The resource object for a host might be a resource pool or a project.
    (On Solaris 10) The resource object for a host might be a resource pool, zone, or a project.
    • To generate a report for the entire host, select the Total Utilization option.
      Select the appropriate time interval from the Time Interval list.
      Click the Update Graph button.
      The CPU and memory resource utilization graphs appear.
    • To generate a report for a resource object in the host, select the Cumulative Utilization by Object option.
      Select the appropriate resource object.
      The CPU and memory resource utilization graphs appear for a maximum of 5 resource objects that have high utilization.
  6. (Optional) To export the last 24 hours of data to a CSV file, click the Export Data button.
    You must wait at least 2 hours after installation of the Performance Reporting Manager software for a CSV report to be available. Data must first be collected and stored in the database from which the report can be drawn. You cannot preview this data in a graph.
    Data exported contains the hourly data for the container for the last 24 hours. Therefore, it is not identical to the data obtained from a daily graph.
