Installing and Administering Solaris Container Manager 1.1
ProcedureTo Request a Resource Utilization Report for a Container
Use this procedure to request CPU and memory utilization reports for a container. The data is based on historical data and is an average of the resources used by active containers that are based on the container.
Steps
  1. Set the browser's cache to refresh every time.
  2. In the Containers view, select the container.
  3. Select the Utilization tab.
    The CPU usage and memory usage of the container for the last 24 hours are displayed.
  4. Click the Graph Properties link.
  5. Choose whether to generate a report for the entire container or for a resource object in the container.
    Note –
    The resource object for a container is a host.
    • To generate a report for the entire container, select the Total Utilization option.
      Select the appropriate time interval from the Time Interval list.
      Click the Update Graph button.
      The CPU and memory resource utilization graphs appear.
    • To generate a report for a resource object in the container, select the Cumulative Utilization by Object option.
      Select the appropriate resource object.
      The CPU and memory resource utilization graphs appear for a maximum of 5 resource objects that have high utilization.
