This appendix contains procedures for installing, setting up, and removing the Solaris Container Manager 1.1 (Container Manager) software at the command line. Command-line installation is an alternative to using the installation wizard.
For the latest information about installing, setting up, and using the software, see the Solaris Container Manager 1.1 Release Notes.
For information about using the installation wizard, see Chapter 2, Container Manager Installation and Setup.
Installation of Container Manager at the command line follows the standard Sun Management Center add-on software installation procedures. For more information about installation of add-on software at the command line, see Appendix B, Using the Command Line for Uninstall, Install, and Setup, in Sun Management Center 3.5 Installation and Configuration Guide.
Container Manager must be installed on the following layers of Sun Management Center 3.5 Update 1b:
Server layer
Agent layer, on all hosts for which you want to generate reports
The interactive es-inst installation script installs the correct Container Manager software packages on the server and agent layers. For all layers, the packages, module configuration files, and libraries are installed in standard Sun Management Center 3.5 Update 1 locations. For more information about the supported platforms and installation requirements, see Container Manager Software Description.
The Container Manager software can be installed at the following times:
At the same time that you install the Sun Management Center 3.5 Update 1b software.
At the same time that you upgrade your existing Sun Management Center 3.5 installation to Update 1b as part of the upgrade procedure.
After you have completed your installation of, or upgraded to, Sun Management Center 3.5 Update 1. In this case, you install the Container Manager software individually.
The Performance Reporting Manager software must also be installed if you want to use the performance and accounting data features of Container Manager. For more information about installation and setup of this software at the command line, see Appendix B, Installing Using the Command Line, in Sun Management Center 3.5 Performance Reporting Manager User’s Guide. If you do not intend to use these features, you do not need to install this add-on software.
For more information and detailed steps using the command line, see Appendix B, Using the Command Line for Uninstall, Install, and Setup, in Sun Management Center 3.5 Installation and Configuration Guide. You can also install additional add-on software, such as Performance Reporting Manager, at the same time.
For more information and detailed steps, see Chapter 5, Upgrading Previous Versions of SyMON and Sun Management Center on the Solaris Platform, in Sun Management Center 3.5 Installation and Configuration Guide. You can also install additional add-on software, such as Performance Reporting Manager, at the same time.
As superuser (su -), run the Sun Management Center 3.5 Update 1b installation script by typing:
# /opt/SUNWsymon/sbin/es-inst |
where /opt is the directory in which Sun Management Center 3.5 Update 1b is installed. Substitute the name of the actual directory if it is different on your system.
Provide the source directory of the Container Manager files when prompted.
Please enter the source directory: |
On SPARC systems, choose from the following:
If installing from the software CD-ROM, type:
# /cdrom/cdrom0/image |
If installing from a directory to which the software has been copied, type:
# disk1/image |
disk1 is the location where the software was copied.
On x86 systems, choose from the following:
# /cdrom/cdrom0/x86/image |
# disk1/x86/image |
To install the Container Manager software, answer “Yes” when prompted.
The es-inst script installs Container Manager. The es-inst script then automatically displays setup prompt.
Determine whether you want to set up Container Manager now or at a later time.
The following is an example of the output you might see:
You must perform setup before using Sun Management Center 3.5 Update 1. Do you want to run setup now (y|n|q) |
To set up the software at a later time, answer n for “No”. When you are ready to run the setup process, see To Set Up Container Manager Individually.
To set up the software now, answer y for “Yes”.
After installation is complete, you must run the Container Manager setup script to configure the server and agent layers. As with installation of the software, you can run the setup process at the time you set up the Sun Management Center 3.5 Update 1b installation or upgrade. You can also set up the software individually, at a later time.
The configuration file changes that occur during the setup process when initiated from the command line are identical to the configuration file changes that occur when using the setup wizard. For more information, see Setting Up Container Manager Software.
For more information and detailed steps, see Appendix B, Using the Command Line for Uninstall, Install, and Setup, in Sun Management Center 3.5 Installation and Configuration Guide.
This procedure assumes that you chose not to set up Container Manager at the end of the installation process.
Run the Sun Management Center 3.5 Update 1b setup script as superuser (su –). Choose one of the following options:
To run setup on all components that are not yet set up, type:
# /opt/SUNWsymon/sbin/es-setup |
To run setup on the Container Manager add-on software only, type:
# /opt/SUNWsymon/sbin/es-setup -p SCM |
where /opt is the directory in which Sun Management Center 3.5 Update 1 is installed. Substitute the name of the actual directory if it is different on your system.
Review the list of components that must be stopped for the set up process to continue.
Confirm that Container Manager is the product to be set up.
When setting up the agent layer, if processor sets are detected on the system that are not associated with a resource pool, select from the following:
Yes – These particular processor sets will be deleted from the system. For Container Manager to function correctly, any processor set that is not associated with a resource pool must be removed as the set might cause problems with pool management. After this selection, these processor sets are automatically deleted, and the setup process continues.
No – These particular processor sets will not be deleted from the system. After this selection, the setup script exits and the Container Manager software is not set up on the system. You are unable to use the Container Manager software on any host on which exist processor sets that are not associated with a resource pool.
Cancel – The setup script exits. The Container Manager software is not set up on the system.
Type the valid user names separated by commas. These users must already be present in the /var/opt/SUNWsymon/cfg/esusers file on the server machine, and must be assigned to either esadm or esdomadm group.
These users will be added to the required profiles (Project Management, Pool Management, Zone Management) if both users and profiles are present as expected. The profiles are based on the Solaris version.
On each agent machine, run the /opt/SUNWsymon/addons/SCM/sbin/scm-poolprof-script.sh script to create the profiles. /opt is the directory in which Container Manager is installed. To run this script, the JAVA_HOME environment variable must have been set to /usr/j2se, or Java must have been installed in /usr/java.
This script will NOT create any Zone Management or Project Management profiles for S9 and S10. This script will ONLY create Pool Management profile for S9 and S10 and Project Management profile for S8.
If any of the predefined Solaris profiles are removed, then Container Manager might not work as expected.
Only the users added in this step will be able to manage zones on S10, resource pools on S9 and S10, and projects on S8, S9, and S10.
If you have previously completed the setup process for other Sun Management Center products, indicate whether you want to run setup again for all software or just the newest add-on software.
When setting up a server layer installation, provide the full path to a directory that has at least 300 Mbytes of free disk space for the database.
Indicate whether you want to start the Sun Management Center agent and server components by answering Y or N.
You receive confirmation when the software is set up.
After the setup procedure is complete, you have the option to start the Sun Management Center processes. For more information, see Chapter 8, Starting and Stopping Sun Management Center, in Sun Management Center 3.5 Installation and Configuration Guide.
The following is an example of the output you see after setup is complete and the Sun Management Center agent and server layers have been started:
Do you want to start Sun Management Center agent and server components now (y|n|q) y
Java server started successfully.
Grouping service started successfully.
Agent started successfully.
Topology service started successfully.
Trap-handler service started successfully.
Configuration service started successfully.
Event-handler service started successfully.
Metadata Service started successfully.
Hardware service started successfully.
Web server started successfully.
Setup of Sun Management Center is complete.
Setup logfile is : /var/opt/SUNWsymon/install/setup_host_name.040408141450.12822
Install logfile is : /var/opt/SUNWsymon/install/install_host_name.040408140547.10929
End of Installation
Exiting Sun Management Center installation.
The es-uninst script removes the Container Manager add-on software. The script removes the Container Manager packages and all the data and configuration changes that are made during setup. The following are removed in addition to the software packages: the module entry from base-modules-d.dat and the application registration from Java Web Console. During the removal process, you are prompted on whether the you want the system to retain the data stored in the database. System resource configuration changes that are made during installation are not removed when the Container Manager software is uninstalled.
As superuser (su —), type:
# /opt/SUNWsymon/sbin/es-uninst |
Select Container Manager from the list of add-on software.
Indicate whether to preserve the data files.
The following is an example of the output that is displayed:
Select Save Data to save all user and configuration data. Your data is saved and can be restored when you re-install Sun Management Center. Do you want to preserve data (y|n|q) |
After the es-uninst script is finished, the Container Manager packages and configuration files are removed. If you chose not to preserve the data files, they are removed as well.
