Installing and Administering Solaris Container Manager 1.1
ProcedureTo Install Container Manager During Sun Management Center Installation
Step
    For more information and detailed steps using the command line, see Appendix B, Using the Command Line for Uninstall, Install, and Setup, in Sun Management Center 3.5 Installation and Configuration Guide. You can also install additional add-on software, such as Performance Reporting Manager, at the same time.
