Installing and Administering Solaris Container Manager 1.1
Project Types
When creating a new container, you must select the project type. A project is a network-wide administrative identifier (ID) for related work. All processes that run in a container have the same project ID, and a container tracks the resources being used with the project ID. The container type is based on which project type is selected when creating the container.
Every container has a project name that is a permanent part of its information. When a container is activated on a host, this project name is added to that host's /etc/project file. This entry remains as long as the container is active on that host.
You cannot have two projects with the same project name active on a host at the same time. This is because processes that run in a container are tracked with the project ID, so every project name on a host must be unique.
When creating user-based and group-based projects, the user or group name becomes part of the project name. For user-based containers, the project name becomes user.username. For group-based containers, the project name becomes group.groupname. Therefore, when creating user-based or group-based projects, you cannot use a user name or group name that duplicates the /etc/project entries for the default containers. For more information, see Default Containers.
You provide a project name of your choosing as part of the creation process for application-based containers. The Project Creation wizard accepts duplicate project names for different application-based projects. But two application-based projects that have the same project name cannot be active on the same host at the same time. Reuse project names when creating application-based projects, only if you plan to activate these containers on different hosts. If you try to activate a second project on a host that already has a project with the identical project name, the activation fails.
The following table provides details about the three project types that are available and which changes occur based on the selection.
Table 3–2 Project Type Details
Project Type
OS Version
Details
User-Based
Solaris 8
Only type of project supported in the Solaris 8 release.
The project name in the /etc/project file becomes user.username. The project becomes the user's primary default project.
Solaris 9 and Solaris 10
The project name in the /etc/project file becomes user.username, with a list of UNIX users who can join this project.
Valid forms are username.
Group-Based
The project name in the /etc/project file becomes group.groupname.
Valid form is groupname.
Application-Based
The project name can be the application name or any other chosen name. The name that is provided is added to the /etc/project file.
A match expression can be provided for automatically moving the matching processes to the project name. This expression is case sensitive.
The corresponding username or groupname under which the processes currently run must be provided.
