Installing and Administering Solaris Container Manager 1.1
ProcedureTo Remove an Alarm Threshold
Steps
  1. If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
  2. In the Hosts view, select the host with which the container is associated.
  3. Select the Projects tab.
    A table appears that lists all containers that are associated with that host.
  4. In the table, click the appropriate project in the Project Name column for which you want to remove an alarm.
    The Properties page for the container appears.
  5. Select the Alarm Thresholds tab.
    The Alarm Thresholds page appears. The values for the alarms that are set for the container are displayed.
  6. Remove the alarm values from the text fields.
  7. Click Save.
    The alarm is no longer set.
