Installing and Administering Solaris Container Manager 1.1
ProcedureTo Move a Container or Host to a Different Group
Steps
  1. If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
  2. Select the appropriate view from the navigation window.
    • To move a container to a different group, select the Containers view. The Containers table is displayed in the right pane.
    • To move a host to a different group, select the Hosts view. The Hosts and Groups table is displayed in the right pane.
  3. To enable the Move button in the table, select the check box for the container or host that is to be moved.
  4. In the right pane, click the Move button.
    A dialog box lists the available groups.
  5. Select the group to which the container or host is to be moved.
  6. Click OK.
    The container or host is moved to the selected group.
