If you want to upgrade the agent layer on multiple hosts with the Container Manager software, you can use the agent update feature. When using the agent update feature, it is best to keep all Container Manager agent machines that are in the same server context at the same Sun Management Center version levels. For more information about server context, see Sun Management Center Architecture in Sun Management Center 3.5 User’s Guide.
For more information about using the agent update feature during installation, see Creating Agent Installation and Update Images in Sun Management Center 3.5 Installation and Configuration Guide.
