Installing and Administering Solaris Container Manager 1.1
ProcedureTo Delete a Resource Pool
Steps
  1. If the Container Manager GUI is not already open, access it as described in To Start the Container Manager GUI.
  2. Select Hosts view by clicking the left tab in the navigation window.
    A list of hosts is displayed in the navigation window.
  3. Select the host name.
    The Resource Pools table is displayed in the right pane.
  4. To enable the Delete button, select the check box next to the resource pool.
    If the Delete button does not become active, then containers are still using this pool and you cannot delete it.
  5. Click the Delete button.
    The selected resource pool is deleted and its name is removed from the tree.
