Solaris Container Manager 1.1 Release Notes
Chapter 3 Documentation Issues
This chapter describes known documentation problems.
Installing and Administering Solaris Container Manager 1.1
This section describes corrections to specific chapters in the Installing and Administering Solaris Container Manager 1.1 book.
Installing At the Command Line
Disregard the information in the second bullet point under “The Container Manager software can be installed at the following times:” in the Installing Container Manager Software section.
Creating Reports and Using Extended Accounting Data
The description of the resource utilization graphs report for Container is incorrect. The corrected version follows:
Container
Data is represented as a percentage of the resource reservations for minimum CPU and memory cap for all active containers. This percentage compares the actual resources used to the resources reserved.
Managing Projects
The second paragraph under the heading of Inactive Project in the Project States section is partially incorrect. The corrected version follows:
All data collected about the project's use of resources while it was active is preserved in the database. However, you cannot request a utilization report for an inactive project.
