Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-lifecycle-module-userprop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--description|-D text] --config|-c name --module|-m name (propertyname=value)+
Use this command to create a lifecycle module user property.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Enter a description of the lifecycle module user property.
Specify the name of the configuration for which you want to create the lifecycle module user properties.
Specify the name of the lifecycle module.
Specify the name and value of the lifecycle module property that you want to create.
wadm create-lifecycle-module-userprop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --module=Lifecycle1 info=creating |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), delete-lifecycle-module-userprop(1), list-lifecycle-module-userprops(1), create-lifecycle-module(1), set-lifecycle-module-prop(1), delete-lifecycle-module(1), get-lifecycle-module-prop(1), list-lifecycle-modules(1)
