Name | Synopsis | Description | Options | Examples | Exit Status | See Also
enable-on-demand-compression <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--uri-pattern|-t pattern] [--no-vary-header|-r] [--fragment-size|-f size] [--compression-level|-l [1-9]/NONE] --config|-c name --vs|-s name
Use this command to enable on-demand compression. A dynamically generated HTML page does not exist until a user asks for it. This is particularly useful for e-commerce based web applications and database-driven sites.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the URI wildcard pattern.
If you specify this option, the Vary: Accept-encoding header is not inserted when a compressed version of a file is selected.
Specify the memory fragment size (in bytes) that has to be used by the compression library to control the rate of compression.
Specify the the level of compression. The range of values is 1–9. The value 1 yields the best speed; the value 9 the best compression. A middle value provides a compromise between speed and compression.
Specify the name of the configuration.
Specify the name of the virtual server.
wadm enable-on-demand-compression --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --vs=vs --fragment-size=100 --compression-level=5 |
The following exit values are returned:
command executed successfully
error in executing the command
