Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
set-custom-resource-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c name --jndi-name|-j name (propertyname=value)+
Use this command to edit custom resource properties. The properties that you can edit are as follows:
enabled - Indicates whether the custom resource is enabled at runtime. The default value is true.
res-type - The type of custom resource.
factory-class - The class that instantiates a naming context which is used to look up the external resource. The value is a fully qualified class name that implements javax.naming.spi.ObjectFactory.
description - The description of the resource.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the JNDI name of the custom resource.
Specify the name and value of the custom resource property that you want to edit.
wadm set-custom-resource-prop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true--no-prompt --rcfile=null --config=config1 --jndi-name=custom enabled=true res-type=samples.jndi.cust-Resource.MyBean factory-class=samples.jndi.cust-Resource.MyCustomConnectionFactory |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), create-custom-resource-userprop(1), delete-custom-resource-userprop(1), list-custom-resource-userprops(1), create-custom-resource(1), delete-custom-resource(1), list-custom-resources(1), get-custom-resource-prop(1)
