NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
get-jdbc-resource-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c name --jndi-name|-jname (propertyname)*
Use this command to view the JDBC resource properties. The properties that you can view are as follows:
enabled - Indicates whether the JDBC resource is enabled at runtime.
jndi-name - The JNDI name of the resource.
datasource-class - The JDBC driver class.
min-connections - The minimum number of concurrent connections to maintain to the database server.
max-connections - The maximum number of concurrent connections to maintain to the database server.
idle-timeout- The timeout (in seconds) after which an idle connection to the database server will close.
wait-timeout - The timeout (in seconds) after which a caller waiting for an available connection to the database server will receive an error.
isolation-level - The level of transaction isolation.
isolation-level-guaranteed - Indicates whether the server sets the isolation level each time a connection is leased to an application.
connection-validation - Specifies how the server validates a connection before "leasing" it to an application.
connection-validation-table-name - The name of the table if the connection-validation is a database table.
fail-all-connections - Indicates whether all connections are immediately closed and reestablished when there is an error while validating a connection.
description - The description of JDBC resource.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the JNDI name of the JDBC resource.
wadm get-jdbc-resource-prop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --jndi-name=jdbc |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), create-jdbc-resource-userprop(1), delete-jdbc-resource-userprop(1), list-jdbc-resource-userprops(1), create-jdbc-resource(1), delete-jdbc-resource(1), list-jdbc-resources(1), set-jdbc-resource-prop(1)
