NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
get-unix-homedir-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c name --vs|-s name (propertyname)*
Use this command to view the properties of the UNIX home directory. The properties that you can view are as follows:
uri-prefix - The URI prefix for the user directory.
sub-dir - The name of the sub directory.
load-db-on-startup - The name of the password file that is loaded at server startup.
user-pwfile - The name of the file that contains the user password.
use-system-pwfile - Indicates whether the users are looked up from the password file specified in user-pwfile option.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the name of the virtual server.
wadm get-unix-homedir-prop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --vs=vs |
The following exit values are returned:
command executed successfully
error in executing the command
