NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
block-reverse-proxy-header <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c config-name --vs|-s vs-name --uri-prefix|-r uri-prefix (param)
Use this command to block a reverse proxy parameter. The parameters that you can block are jroute, ip, via, cipher, proxy-agent, proxy-auth, keysize, secret-keysize, ssl-id, issuer-dn, user-dn, and auth-cert.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the name of the virtual server.
Specify the URI prefix of the reverse proxy.
wadm block-reverse-proxy-header --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --vs=vs1 --uri-prefix=/reverse jroute |
The following exit values are returned:
command executed successfully
error in executing the command
