NAME | Synopsis | Description | Options | Examples | Exit Status | See Also
expire-lock <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --vs|-s vs-name --lock-uri|-l uri --opaque-token|-o token --collection-uri|-d uri --config|-c config-name
Use this command to expire a lock.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the configuration where the locks exist.
Specify the name of the virtual server.
Specify the URI on which the lock exists.
Specify the name of the collection URI.
Specify the ID of the lock that you want to expire. Lock IDs are displayed when you run the list-lock command.
wadm expire-lock --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --vs=config1 --collection-uri=/dav1 --lock-uri=/dav1/file.html --opaque-token=opaquelocktoken |
The following exit values are returned:
command executed successfully
error in executing the command
