NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
get-lifecycle-module-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --module|-m name --config|-c config-name (propertyname)*
Use this command to view the lifecycle module properties. The properties that you can view are as follows:
enabled - Indicates whether the lifecycle module is enabled at runtime.
name - The name that uniquely identifies the lifecycle module.
class - The class that implements the lifecycle module.
load-order - The order in which the lifecycle module is loaded. It is recommended that you choose a load-order value that is greater than or equal to 100 to avoid conflicts with the internal lifecycle modules.
is-failure-fatal - Indicates whether the server should treat exceptions thrown during the initialization of lifecycle module as fatal.
class-path - The class path for the lifecycle module.
description - The description of the lifecycle module.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the lifecycle module.
Specify the name of the configuration.
wadm get-lifecycle-module-prop --user=admin --port=8989 --password-file=../admin.passwd --host=serverhost --ssl=true --no-prompt --rcfile=null --config=config1 --module=LifecycleProp |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), create-lifecycle-module(1), set-lifecycle-module-prop(1), delete-lifecycle-module(1), list-lifecycle-modules(1), create-lifecycle-module-userprop(1), delete-lifecycle-module-userprop(1), list-lifecycle-module-userprops(1)
