NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
set-admin-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--node|-n node-name] [--set-password|-r] (propertyname=value)+
Use this command to edit the administration node properties. The properties that you can edit are as follows:
description - The description of the node.
server-user - The user ID of the server user, for example, root.
ssl-port - The SSL port if the server uses SSL connection to communicate.
non-ssl-port - The non-SSL port if the server uses non-SSL connection to communicate.
java-home - The location of the JDK directory. The JDK must have permission for the account the server runs as.
log-level - The log verbosity for the server.
log-file - The path of the server's log file.
admin-user - The user name of the authorized Web Server administrator.
access-log-file - The path of the server's access log file.
Note: If you modify the java-home property, stop and start the administration server on the specified node for the changes to take effect. If you make changes to any other properties, restart the administration server on the specified node.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the node.
Specify this option to change the administration server user password.
Specify the name and value of the administration node property that you want to edit.
wadm set-admin-prop --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null log-level=fine is-admin-server=false |
The following exit values are returned:
command executed successfully
error in executing the command
