NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
set-keep-alive-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c config-name (property-name=value)*
Use this command to edit the keep-alive properties. The properties that you can edit are as follows:
enabled - Indicates whether the server supports keep-alive connections. The default value is true.
threads - The number of keep-alive subsystem threads. The range of values is 1–128. The default value is default.
max-connections - The maximum number of concurrent keep-alive connections the server will support. The range of values is 1–1048576. The default value is default.
timeout - The timeout (in seconds) after which an inactive keep-alive connection will be closed. The range of values is 0.001–3600.
poll-interval - The interval (in seconds) between polls. The range of values is 0.001–1.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
| wadm set-keep-alive-prop --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null--config=config1 enabled=false poll-interval=0.002 threads=2 timeout=60 max-connections=400 |
The following exit values are returned:
command executed successfully
error in executing the command
