NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
set-servlet-container-prop <connect_options> [--echo|-e] --no-prompt|-Q] [--verbose|-v] --config|-c config-name (property-name=value)+
Use this command to edit the Servlet container properties. The properties that you can edit are as follows:
dynamic-reload-interval - The interval when the server checks the deployed web applications for modifications. The range of values is 1–60, or –1 if dynamic reloading should be disabled. The default value is –1.
log-level - The log verbosity for the Servlet container. The values can be finest (most verbose), finer, fine, info, warning, failure, config, security, or catastrophe (least verbose).
anonymous-role - The name of the default or anonymous, role assigned to all principals. The default role is ANYONE.
single-threaded-servlet-pool-size - The number of Servlet instances to instantiate per SingleThreadedServlet. The range of values is 1–4096.
cross-context-allowed - Indicates whether the request dispatchers are allowed to dispatch to another context. The default value is true.
reuse-session-id - Indicates whether any existing session ID number is reused when creating a new session for that client. The default value is false.
encode-cookies - Indicates whether the Servlet container encodes the cookie values. The default value is true.
dispatcher-max-depth – The maximum depth for the Servlet container allowing nested request dispatches. The range of values is 0–2147483647. The default value is 20.
secure-session-cookie — Controls the conditions under which the JSESSIONID cookie is marked secure. The values can be as follows:
dynamic — marks the cookie secure only when the request is received on a secure connection.
true — always marks the cookie secure.
false — never marks the cookie secure.
The default value is dynamic.
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the name and value of the Servlet container property that you want to edit.
wadm set-servlet-container-prop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 cross-context-allowed=false dispatcher-max-depth=15 dynamic-reload-interval=5 encode-cookies=false log-level=finer reuse-session-id=true secure-session-cookie=false single-threaded-servlet-pool-size=2 |
The following exit values are returned:
command executed successfully
error in executing the command
