Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-jvm-options <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--profiler|-rprofiler-name] [--debug-options|-d] --config|-c config-name (jvm_option_name=jvm_option_value) [:jvm_option_name=jvm_option_value]*
Use this command to create Java Virtual Machine (JVM) options. You must restart the server for newly created JVM options to take affect.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration for which you want to create the JVM options.
Specify the name of the JVM profiler to which these JVM options apply.
If you specify this option, the command creates a JVM option of type debug.
jvm_option_name=jvm_option_value |
Specify the name and value of the JVM option that you want to create. The left side of the equal sign (=) is the JVM option name. The right side of the equal sign (=) is the JVM option value. Use a colon (:) as a delimiter for multiple options. |
While specifying the JVM options, use hyphens (--) as a delimiter. Else, the JVM options that you define will be interpreted as a CLI option.
wadm create-jvm-options --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 -Dhttp.proxyHost=proxy.bay.com -Dhttp.proxyPort=8080 |
The following exit values are returned:
command executed successfully
error in executing the command
