Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
get-document-footer-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--uri-pattern|-t pattern] --config|-c config-name --vs|-s vs-name (propertyname)*
Use this command to view the document footer properties. The properties that you can view are as follows:
mime-type - The type of files to be included in the footer.
date-format - The format of date displayed in the document footer.
footer - The text that appears in the document footer. The maximum number of characters for a document footer is 765.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the URI wildcard pattern.
Specify the name of the configuration.
Specify the name of the virtual server.
| wadm get-document-footer-prop --user=admin --host=serverhost --password-file=../admin.passwd --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --vs=config1_vs1 footer |
The following exit values are returned:
command executed successfully
error in executing the command
