Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
get-external-jndi-resource-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] --config|-c config-name --jndi-name|-j name (propertyname)*
Use this command to view the external Java Naming and Directory Interface (JNDI) resource properties. The properties that you can view are as follows:
enabled - Indicates whether the JNDI resource is enabled at runtime.
jndi-name - The name of the JNDI resource.
jndi-lookup-name — The JNDI lookup name of the resource.
res-type - The resource type.
factory-class - The class that instantiates resources.
description - The description of the resource.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the name of the configuration.
Specify the name of the external JNDI resource.
| wadm get-external-jndi-resource-prop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --jndi-name=external-jndi |
The following exit values are returned:
command executed successfully
error in executing the command
help(1), create-external-jndi-resource-userprop(1), delete-external-jndi-resource-userprop(1), list-external-jndi-resource-userprops(1), create-external-jndi-resource(1), set-external-jndi-resource-prop(1), delete-external-jndi-resource(1), list-external-jndi-resources(1)
