Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
get-on-demand-compression-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--uri-pattern|-t pattern] --vs|s vs-name --config|-c config-name (propertyname)*
Use this command to view the on demand compression properties. The properties that you can view are as follows:
insert-vary-header — Indicates whether to insert the Vary: Accept-encoding header. If set to Yes, a Vary: Accept-encoding header is inserted when a compressed version of a file is selected. If set to No, the header is never inserted. The default, the value is Yes.
compression-level — Specifies the level of compression. Choose a value between 1 and 9. The value 1 yields the best speed; the value 9 the best compression. The default value is 6, a compromise between speed and compression.
fragment-size — Specifies the memory fragment size in bytes to be used by the compression library to control how much to compress at a time. The default value is 8096.
enabled — Indicates whether on—demand compression is enabled at runtime.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the URI wildcard pattern.
Specify the name of the virtual server.
Specify the name of the configuration.
| wadm get-on-demand-compression-prop --user=admin --password-file=../admin.passwd --host=serverhost --port=8989 --ssl=true --no-prompt --rcfile=null --config=config1 --vs=vs compression-level |
The following exit values are returned:
command executed successfully
error in executing the command
