Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
set-cert-trust-prop <connect_options> [--echo|-e] [--no-prompt|-Q] [--verbose|-v] [--token|-t name] [--token-pin|-P name] [--nickname|-n nickname] --config|-c config-name (propertyname=value)+
Use this command to edit the certificate trust properties. A certificate is issued and digitally signed by a CA. You decide which CAs you trust enough to serve as verifiers of other users' identity. Before requesting a server certificate, you must create a trust database. The properties that you can edit are as follows:
is-client-ca — Indicates if this certificate is trusted to sign client certificates.
is-server-ca — Indicates if this certificate is trusted to sign server certificates.
For connect_options description, see help(1).
Specify this option to print this command on the standard output before executing. This option also prints the default value for all the non-mandatory options that you do not provide in the command.
If you specify this option, wadm will not prompt you for passwords while executing this command. Use this option if you have defined all passwords in a password file and specified the file using the --password-file connect_option.
Specify this option to display a verbose output.
Specify the token (cryptographic device), which contains the encrypted public key.
Specify the Personal Identification Number (PIN) required to initialize the token. You can also define the token-pin in the password file.
Specify the short name or the nick name of the certificate.
Specify the name of the configuration.
Specify the name and value of the certificate trust property that you want to edit.
| wadm set-cert-trust-prop --user=admin --host=serverhost --password-file=certdb.newpasswd --port=8989 --ssl=true --prompt=false --rcfile=null --config=config1 --token=internal --nickname="Cert Manager-Sun" is-client-ca=true is-server-ca=false |
The following exit values are returned:
command executed successfully
error in executing the command
