NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
configure-ha-cluster
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host  host]
[--port port] [--secure| -s ] [ --user  admin_user]
[--passwordfile filename] [--help]
[ --devicesize  devicesize] [--haagentport port_number]
[--haadminpassword password]
[--haadminpasswordfile file_name]
--hosts hadb-host-list [--autohadb={true|false}]
[ --portbase  port_number]
[--property (name=value)[:name-value]*]
{clusterName}
This command requires the HADB software. This command is available only in domains that are configured to support clusters, such as domains that are created with the cluster profile or the enterprise profile. For information about profiles, see Usage Profiles in Sun Java System Application Server 9.1 Administration Guide.
The configure-ha-cluster command performs the following tasks:
Verifies that the cluster exists.
Verifies that the cluster is standalone (an example of this is, that the cluster doesn't share its configuration with any other cluster).
Checks if a database with the same name as the cluster already exists. If so, an error is logged and the command performs the next task.
Creates an HA database with the same name as the cluster.
Creates the correct tables in the database.
Creates and/or modifies the appropriate resources in domain.xml.
This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
This is the device size in MegaBytes (MB). The valid range is between 208MB and 8+ gigabytes (GB).
This is the number of the HA agent port. The default is 1862.
This is the HA administrator's password.
The file containing the high-availability password associated with the administrative instance. The password is defined in the following form: HADBM_ADMINPASSWORD=password, HADBM_DBPASSWORD=password, HADBM_SYSTEMPASSWORD=password. Where password is the actual HA administrator password for the domain.
This is a list of comma separated host names where the HADB instance is configured. The number of hosts must be greater than 1 and must be an even number. The same host names can be repeated. Use fully qualified hostnames when specifying the hostlist interfaces explicitly for hosts with multiple network interfaces.
If set to true, the HADB database associated with the cluster is automatically started, stopped, or deleted if you start, stop, or delete the cluster. The default is false. To override this setting, use the hadboverride option in start-cluster, stop-cluster, or delete-cluster.
The starting port number for the HADB server. Default is 15000. Valid values are between 10000 and 63000.
This is a list of property name/value pairs, which are separated by a colon.
The readable configuration attributes are as follows:
 Variable  |
 Range  |
 Default  |
 ConnectionTrace  |
 true/false  |
 false  |
 CoreFile  |
 true/false  |
 false  |
 DatabaseName  |
 hadb  |
 DataBufferPoolSize  |
 16–2047  |
 200 MB  |
 DataDeviceSize  |
 32–262144  |
 1024 MB  |
 DevicePath  |
 n/a  |
 n/a  |
 EagerSessionThreshold  |
 0–100  |
 50 (% of NumberOfSessions)  |
 Eager SessionTimeout  |
 0–2147483647  |
 120 seconds  |
 EventBufferSize  |
 0–2097152  |
 0 MB  |
 HistoryPath  |
 n/a  |
 n/a  |
 InternalLogBufferSize  |
 4–128  |
 12 MB  |
 JdbcUrl  |
 n/a  |
 n/a  |
 LogBufferSize  |
 4–2047  |
 48 MB  |
 MaxTables  |
 100–1100  |
 1100  |
 NumberOfDataDevices  |
 1–8  |
 1  |
 NumberOfLocks  |
 20000–1073741824  |
 50000  |
 NumberOfSessions  |
 1–10000  |
 100  |
 PackageName  |
 n/a  |
 V4.x.x.x  |
 PortBase  |
 10000–63000  |
 15000  |
 RelalgDeviceSize  |
 32–262144  |
 128 MB  |
 SQLTraceMode  |
 none/short/full  |
 none  |
 SessionTimeout  |
 0–2147483647  |
 1800 seconds  |
 StartRepairDelay  |
 0–100000  |
 20 seconds  |
 StatInterval  |
 0–600  |
 600 seconds  |
 SyslogFacility  |
 <facility>  |
 local0  |
 SyslogLevel  |
 <level>  |
 warning  |
 SyslogPrefix  |
 <string>  |
 hadb-<db_name>  |
 TakeoverTime  |
 500–16000  |
 10000 MS  |
This is a basic example of how the command is used.
asadmin> configure-ha-cluster --user admin --passwordfile passwordfile --hosts red.iplanet.com.host1,red.iplanet.com.host2 cluster1 Command configure-ha-cluster executed successfully  |
