NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-admin-object   --restype aorestype
 --raname  resource_adapter_name
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host  host]
[--port port] [--secure| -s ] [ --user  admin_user]
[--passwordfile filename] [--help]
[ --enabled ={true | false}] [--target target] [--description text]
 [--property name=value[:name=value]*]
 jndi_name
This command creates the administered object that has a specified JNDI name.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
Specifies the target on which you are creating the administered object. Valid values are
server, which creates the administered object for the default server instance server and is the default value
configuration_name, which creates the administered object for the named configuration
cluster_name, which creates the administered object for every server instance in the cluster
instance_name, which creates the administered object for a particular server instance
Specifies if this object is enabled. The default value is true.
This option is used to administer the object resource types, as defined by the resource adapter in the ra.xml file.
This is the name of the resource adapter associated with this object.
This option is the text description of the administered object.
This option describes the “name/values” pairs for configuring the resource.
The javax.jms.Queue resource type is obtained from the ra.xml file. The jmsrar.rar must be deployed prior to executing this command.
asadmin> create-admin-object --user admin1 --passwordfile passwords.txt --restype javax.jms.Queue --raname jmsra --description "sample administered object" --property Name=sample_jmsqueue jms/samplequeue Command create-admin-object executed successfully  |
