NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-iiop-listener
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host host]
[--port port] [--secure| -s ] [ --user admin_user]
[--passwordfile filename] [--help]
--listeneraddress address
[--iiopport iiop-port-number] [--securityenabled=false]
[--enabled=true] [--property (name=value)[:name=value]*]
[--target server] listener_id
The create-iiop-listener command creates an IIOP listener. This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
Either the IP address or the hostname (resolvable by DNS).
The IIOP port number. The default value is 1072.
If set to true, the IIOP listener runs SSL. You can turn SSL2 or SSL3 ON or OFF and set ciphers using an SSL element. The security setting globally enables or disables SSL by making certificates available to the server instance. The default value is false.
If set to true, the IIOP listener is enabled at runtime.
Optional attribute name/value pairs for configuring the IIOP listener.
This option is valid only in domains that are configured to support clusters, such as domains that are created with the cluster profile or the enterprise profile. Specifies the target for which you are creating the IIOP listener. Valid values are
server, which creates the listener for the default server instance server and is the default value
configuration_name, which creates the listener for the named configuration
cluster_name, which creates the listener for every server instance in the cluster
stand-alone_instance_name, which creates the listener for a particular stand-alone server instance
The following command creates an IIOP listener named sample_iiop_listener:
asadmin> create-iiop-listener --user admin --passwordfile passwords.txt --host host1 --port 4848 --listeneraddress 192.168.1.100 --iiopport 1400 sample_iiop_listener Command create-iiop-listener executed successfully. |
The following command creates an IIOP listener named iiop_listener_2 for the cluster mycluster. It uses the target option. This option is valid only in domains that are configured to support clusters, such as domains that are created with the cluster profile or the enterprise profile.
asadmin> create-iiop-listener --user admin --passwordfile passwords.txt --host host1 --port 4848 --listeneraddress 0.0.0.0 --iiopport 1401 --target mycluster iiop_listener_2 Command create-iiop-listener executed successfully. |
