NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-javamail-resource
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host  host]
[--port port] [--secure| -s ] [ --user  admin_user]
[--passwordfile filename] [--help]
 [ --target  target]
 --mailhost hostname --mailuser username
 --fromaddress address [--storeprotocol imap]
 [--storeprotocolclass com.sun.mail.imapIMAPStore]
 [--transprotocol smtp] [--transprotocolclass com.sun.mail.smtp.SMTPTransport]
 [--debug=false] [--enabled=true]
 [--description text] [--property (name=value)[:name=value]*]
 jndi_name
The create-javamail-resource command creates a JavaMail session resource. This command is supported in remote mode only.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
This option specifies the target for which you are creating the JavaMail session resource. Valid values are:
server, which creates the resource for the default server instance. This is the default value.
domain, which creates the resource for the domain
cluster_name, which creates the resource for every server instance in the cluster
instance_name, which creates the resource for a particular server instance
The DNS name of the default mail server. The connect methods of the Store and Transport objects use this value if a protocol-specific host property is not supplied. The name must be resolvable to an actual host name.
The name of the mail account user provided when connecting to a mail server. The connect methods of the Store and Transport objects use this value if a protocol-specific username property is not supplied.
The email address of the default user, in the form username@host.domain.
The mail server store protocol. The default is imap. Change this value only if you have reconfigured the Application Server's mail provider to use a nondefault store protocol.
The mail server store protocol class name. The default is com.sun.mail.imap.IMAPStore. Change this value only if you have reconfigured the Application Server's mail provider to use a nondefault store protocol.
The mail server transport protocol. The default is smtp. Change this value only if you have reconfigured the Application Server's mail provider to use a nondefault transport protocol.
The mail server transport protocol class name. The default is com.sun.mail.smtp.SMTPTransport. Change this value only if you have reconfigured the Application Server's mail provider to use a nondefault transport protocol.
If set to true, the server starts up in debug mode for this resource. If the JavaMail log level is set to FINE or FINER, the debugging output will be generated and will be included in the server log file. The default value is false.
If set to true, the resource is enabled at runtime. The default value is true.
Text providing some details of the JavaMail resource.
Optional attribute name/value pairs for configuring the JavaMail resource. The JavaMail API documentation lists the properties you might want to set.
The JNDI name of the JavaMail resource to be created. It is a recommended practice to use the naming subcontext prefix mail/ for JavaMail resources.
The following command creates a JavaMail resource named mail/MyMailSession. The escape character (\\) is used in the --fromaddress option to distinguish the dot (.) and at sign (@). The JNDI name for a JavaMail session resource customarily includes the mail/ naming subcontext.
asadmin> create-javamail-resource --user admin --passwordfile passwords.txt --host fuyako --port 7070 --mailhost localhost --mailuser sample --fromaddress sample\\@sun\\.com mail/MyMailSession Command create-javamail-resource executed successfully.  |
