NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-jbi-application-variable
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host  host]
[--port port] [--secure| -s ] [ --user  admin_user]
[--passwordfile filename] [--help]
[ --target  target name |server | domain ]
--component component name
(name=[type]value)
[,name=[type]value]* | filepath
The create-jbi-application-variable command creates the application variables for the specified component. Application variables are set using the following format name=[type]value. If the
type is not specified, the default type String will be used. The valid types are String, Number, Boolean and Password.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
The name of the target. Specify this option only if the JBI component is deployed in a multiserver environment with a DAS. If the service assembly is not deployed in a multiserver environment with a DAS, this option is ignored. Valid values are:
server, which deploys the JBI component on the embedded DAS instance. This is the default value.
cluster_name, which deploys the JBI component on every server instance in the cluster.
instance_name, which deploys the JBI component for the named unclustered server instance.
The name of the component for which the variable will be created.
Contains name=value pairs separated by a comma, or a name of a file that contains the name=value pairs for the application variables that will be created in the properties
file. If the operand contains spaces, the operand must be specified within double quotes. If the type is not specified, the default type String will be used. The valid types are String, Number, Boolean and Password.
The location of the archive file that contains the JBI component attributes.
asadmin> create-jbi-application-variable --component=cli-config-binding FirstName=[String]Fred,LastName=Smith,t=[BOOLEAN]true,f=[BOOLEAN]false Command create-jbi-application-variable executed successfully.  |
update-jbi-application-variable(1), delete-jbi-application-variable(1), list-jbi-application-variables(1)
